Timely Article
singh
Member Posts: 866
I made some comments about diamond plate.
Please don't take it the wrong way, your work is great !!
I just think it does little for the system as a whole , and adds cost.
Devan
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=377&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Devan
John Sigenthaler's
latest article in P&M was very timely for me. It's all about simplifying hydronic systems. I have just been called in on a companys first try at a radiant floor. It was not working well. The whole first floor is 5000 sq ft of in slab concrete radiant floor. Upstairs has 2 small bathroom with quik trak. The system supporting this floor was an WM Ultra mod con boiler, a Wirsbo 311 propanel, with another 201 vs propanel attached to that. This set up gave the contractor the ability to do domestic hot water, (Loop not used) high temperature zones, (used incorrectly) and two separate variable injection temperature loops. The quik trak is 4-200 ft loops all on a Taco 0011. Ack! 4 different temps and zones available. How many different temps did they need? Just one. :O The in slab radiant floor and quik trak are close enough in temperature needs, they didn't need more than one temp. Talk about overkill. They have a temperature responsive control built into the boiler they could have used (they now have 3 Weather responsive controls in the system) when all they needed was a circ and some zone valves. (A variable speed cir would be sweet on this set up) And on top of all that...they piped it all wrong. To the contractors credit he didnt run away. He tried until he knew he was over his head and is working with the Homeowner to make it right. The Homeowner found me and enlisted me to help. But back to the Siggy article. Simplify, simplify, simplify. Good article, and very timely for me. WW
That article resonated with me too.
"Just because we can, doesn't mean we should."
That article really made me stop in my tracks. When I start on a job design, I look at function, aesthetics, and service-ability. Simplicity was a function that I had not been factoring in. I have completed simple jobs, but it was not one of my primary concerns.
I think this whole winter season has taught me that I had better simplify when I can.
Denver Wetstock is a scant few weeks away. Looking forward to meeting up with my wallie friends.
Regards,
PR0 -
Great
Welcome to revolution : )
There was some discussion on this at the RPA site also.
Devan
It was an eye-opener
Life will be real nice and simple once the ECM-driven pumps hit the market en-masse.0 -
article
is it accessable on line?0 -
mark
thanks for the link - good article
and through a lack of knowledge on my part, the system in my house was kept down to a simple 4 loop/2 zone system that's controlled with one stat and two mixing valves0
- 84.3K THE MAIN WALL
- 2.9K A-C, Heat Pumps & Refrigeration
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 44 Chimneys & Flues
- 1.8K Domestic Hot Water
- 4.8K Gas Heating
- 120 Geothermal
- 156 Indoor-Air Quality
- 3K Oil Heating
- 57 Pipe Deterioration
- 794 Plumbing
- 5.4K Radiant Heating
- 370 Solar
- 14.1K Strictly Steam
- 3.1K Thermostats and Controls
- 39 Industry Classes
- 80 Job Opportunities
- 22 Recall Announcements
