Woodstove boiler conversion
[Deleted User]
that it was to convect up? with the circ on, if the water's traveling too fast through the hex, it won't pick up much heat
wood stove boiler conversion
Yeah I know it's not to code, dangerous, etc. etc. blah, blah ,blah so don't bother telling me. I installed a heat exchanger in my 70kbtu wood stove to supplement my rads. I welded it together using 1.5" steel so its' a series of S's about 10"x20" with 3/4 nipples out the back of the stove. Feed had a check valve and the out has temp/press/200degree-150psi blow out manifold. This is all in parallel w/ my rads on the same floor. I fired it up today and in 15 minutes it blew out due to high temp. I was led to believe through convection or magic it would circulate itself. So I turned on the circulator on the oil/furnace and its no longer blowing out but not transferring too much heat. I've got some ideas but would like to hear yours.
you guessed it
magic should have made it work!0 -
You probably need
a buffer tank, also be careful about drawing too much heat away with the water, you can create a lot of creosote in the wood stove exhaust. I built a similar log holder- heat exchanger in my fireplace, but I removed it because of the creosote and increased fire hazard. Thanks, Bob Gagnon
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
gettin closer
i put a surface mounted aqua stat and it kicks the circ on @170/150 seems to be working ok, but only the first rad gets hot and I mean HOT! other ones hardly warm up. the circ runs about 30sec. w/ 1/2" feeds. If i set the stat higher the relief valve blows off.0
- 167 Indoor-Air Quality
