Piping Probelm ?
John Faust
Member Posts: 13
Thanks Ted for convering the pics. The boiler is non condensing - sorry the drawing's are pretty light.
Piping Problem?
I recently looked at a system shown in existing attachment.
The question I have is will the radinat loop with the mixing valve work as shown or should it be piped as shown in the proposed. Why or why not?
Also, what is the purpose of the loop with pump #3. Could you not eliminate it altogether and just pipe p4 as secondary loop?0 -
Piping
I converted the pics to PDF. Though they would be useful.0 -
If you are using "the new condensing Boiler" why do you not adjust it to the Proper temp vs.Installing all the Mixing valves and what seams to be an injection system to?HM.0
