Labor rate
Steve_35
Member Posts: 545
If you're charging a labor rate that covers all of your expenses and results in a net profit and you're billing service at T&M, then you could use the same rate for both.
If you're billing FR for service, then you may well be using different hourly rates because labor efficiency comes into play. You will likely have fewer billable hours with FR service than you will with installs.
We use significantly different labor rates for service vs installs.
Labor rate
When you are creating a proposal for a new radiant system and you determine that it will take x hours to complete, is the labor rate you multiply by said hours the same rate you'd charge for a service call? Just wondering if most use different labor rates.0 -
different
We hava a truck charge for the first hour rate with a minimum hour charge. When i a bidding a radiant job i figure an hourly rate per man based on the size of the job. I am sure many guys here have a formula for this.0 -
Varying rates for install/service.
For installs the rate is different since you can bill more hours per week than you can service. Install also have two differing rates depending on the project scope and urgency.
Service, on the other hand, has minimum service visits for different travel "zones" for urgent stuff and then a planned service rate for other things.
All of it comes down to billable hours. How many and what type.0 -
labor rate
My experience level, licensing level,abilities or operating costs dont' change whether I'm doing service work or installation. The rate is the same. I DO charge more when doing consulting work, but to answer your question, same me/same rate.
labor rate
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
