baseboard performance curves
J.C.A._3
J.C.A._3 Member Posts: 2,980
Do you find it as humorous as I do that most heating... "curves", seem to follow a pretty much "straight" line.?
I will say that when I show them to Savvy customers, they seem to see the same. Who am I to argue? This temp. ...that temp...pretty F=IN' linear...
But what do I know....I'm just a cellar dweller. Chris
  • master3015
    master3015 Member Posts: 1
    Does anyone have a chart showing the btuhr output at different temperatures. I'd like it for slant fin, but anyone's will do. I know I have it somewhere in my library but for the life of me I can't seem to find it.
  • Brad White_185
    Brad White_185 Member Posts: 265
    Slant Fin's Web Site
    has all you need but it is in tables, not curves.
    If you do make it into a chart (by hand or Excel) it will appear to be pretty linear, at least when I did it once before. Slant-Fin does list outputs for lower water temperatures so extends the plotting range.
    Most manufacturers will also have tabular data on line too.
    Tube size, fin size, spacing, number of tiers, enclosure stack height...those and other factors influence output appreciably. Flow rate not as much as you think.
  • Uni R_2
    Uni R_2 Member Posts: 589
    for Slant Fin 30
    http://tinyurl.com/2kfdzn
