?? on simple energy management system
tim smith
Member Posts: 2,886
The only way that I could do this is when they come out with their gateway which is do out some time this year or or or or or or or? Also client does not want to control on a computer don't you know!
?? on simple energy management system, any ideas
I have a client who in the 11th hour in rough in has said they want a simple control system but house has 5 zones and they want small sensors/thermostats in each zone, not noticeable of course. Also they want a central thermostat/keypad on main floor that they could make all changes to all areas from. And they will I am sure need adjustability at each zone location also. But "simple" don't you know. Byt the way, cost not really a factor. Aaaaaargh. You all have anything that you have favored and used. Thanks in advance, Tim0 -
Check with Tekmar.0 -
Tim, call me. I have been working with a company out of Bellvue that is making the PERFECT control for your needs. We are beta testing it right now at one of our residential jobs. Final product is coming out next month. All wireless on the touch panel. You only need to run sensors back to the controller, and the sensors get mudded and painted over.0 -
Check i Worx..or www.innovextechnologies.com0 -
Thanks Josh & Derheatmeister
