Geo payback calc programs
John_201
Member Posts: 25
Excellent free software tools here (Excel based) - Geo, solar hot water, PV, wind, etc.
http://www.retscreen.net/ang/d_o_view.php
Hi All,
Was wondering if anyone knows where I could find a computer based program that would calculate the payback of a Geo system over conventional? I am looking for a program where you can input fuel costs, heating load etc.
Thanks,
Steve Allen0 -
Payback Calcs
I would suggest that you contact the International Ground Source Heat Pump Association(IGSHPA) or Air Conditioning Contractors of America (ACCA) for their programs. These are relatively unbiased and based upon rational engineering.0 -
calc.
Siggy's HDS program has what you need.0 -
Manufacturers
Steve, I know some of the manufacturers have design software that will do this. I have software that does just what you're describing. I was given it by a local wholesaler. I'm not sure if it it's completely unbiased but it is a good starting point none the less. The software I use is : http://www.hydroheat.com/software.htm
Good luck, Rich L0 -
This will get you in the ballpark until you are ready to spend the dough on software:
Water Furnace Geothermal Savings Calculator0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
