First floor zone cold?
CC&CP
Member Posts: 1
The house is a raised ranch with a 10 yr old hydronic boiler and the heating has been fine until now. The first problem was a clicking noise coming from what appears to be coming from the flo check valve. So I bleed the zone thinking that it was air in the system. The noise stopped but it eventually came back only this time we weren't getting any heat on the first floor. Its a two zone system and the second floor is fine when it comes to heat. Now when the noise came back I bleed the line again but i only got two and half gallons of water from it and not alot of air. After that, i'm still not getting heat on the first floor. We have baseboard heaters. Any suggestions?
