Adding a Hot Water Loop on a One Pipe Steam System
adambuild
Member Posts: 422
Yes!
Adding A Hot Water Loop on a Steam System
I read somewhere that Dan explains/illustrates this in one of his books. Which one?0 -
As Dan always says, "It pays to wander off The Wall!" The info you're looking for can be found here: http://www.heatinghelp.com/heating_howcome6.cfm
It works great long-term as long as you use a bronze/non-wet rotor circ! Good luck, Adam0 -
Thanks for the info Adam. Is that in his HowCome Book?
