economite startup
bob_50
Member Posts: 306
what model economite you have. There was another model that didn't use a conventional gas valve. The gas valve was operated by a centrifugal mechanism in the blower, no electricity. To light the pilot you will see a small metal toggle switch on the side of the control box, it's spring loaded in the off position. When you hold the switch down you energize a small coil of nicrome wire that is next to the pilot.
anyone have....
a few tips on how to start up an old conversuion burner. This one has no pezio ignightor. I can't quite see how to light up the thermocoulpe from the motor side anfter pulling off the cover. Its in a very old weil-Mcl 57....It will be coming out soon , Very soon. kpc0 -
I`ve been waiting
for an excuse to scan this Kev, does this help???
Dave0 -
thats it!
it will allow them to get into the house...it was winterized in May when the bank forclosed.....ty,kpc0
