Polyethelene (black foam) pipe insulation
Thanks db!
  • Apprentice_3
    Apprentice_3 Member Posts: 22
    pipe insulation.
    I was wondering, does anyone use the PE black foam-type pipe insulation? It looks similar to refrigerant pipe insulation, except that the texture is slightly different and it's available in (I think) 8-foot rigid lengths. A version of it, usually in 4-foot lengths, can be found in pretty much any hardware store. So is this stuff any good? How does the heat loss through this insulation compare to that of, say, fiberglass? Can it be successfully used on a heating system?
    Most of my experience is in the commercial/industrial field where we use fiberglass pipe insulation.
  • don_52
    don_52 Member Posts: 199
    Insulation
    Addam,
    I attached a data sheet, with values. From what I recall
    this is "fairly typical" of the better brands.
    HTH, Regards, db
    hot_rod Member Posts: 27,487
    200F is pushing it
    in my opinion. i've tried that foam on a few high temperature wood boiler installs. Not too impressed.
    If you plan on running above 180F extended go with fiberglass or TechLite melamine insulation.
    hr
  • Al Corelli_2
    Al Corelli_2 Member Posts: 395
    Saw This
    A customer has both types of "black" insulation on his steam mains. Yes, I said steam mains.
    The A/C type (Armaflex) is melted to the 2" main as if you took a torch and burned it on.
    The Closed cell (ThermaCell) type is hanging off like dripping candle wax.
    The basement smelled of burnt plasti/rubber. He thought ols steam systems were supposed to smell like that.
    Fiberglass is the insulation to use for residential steam systems, in my opinion.
