panel rad on same zone as fin tube
kpc_10
Member Posts: 18
if you add a TRV on there. If that closes the head pressure will jump and flow will be dramaticly decreased...kpc
Do panel radiators work well if they are installed on a zone with fin tube baseboard0 -
Only if
you use scoop tee's. You can't just pump thru it.
couple of scoop tee's and you'll be fine.
Scott
What is a scoop tee? is it the bypass setup?0 -
I would also add
that ideally the panel radiator wants to be "last in line", served after the fin-tube. In other words, fin-tube all things being equal works better at higher water temperatures. The panel radiator has a higher radiant output which will at least be perceptible even at slightly lower water temperatures. Give the fin tube first crack at it.0 -
scoop tees
Is it the same as a monoflow? Never heard them called scoop tees.0
