Burnham Series 2 - banging
combustion issue?
Burnham Series 2 boiler - banging
I had my old boiler replaced, complete w/ circ pumps, expanaion tank, etc. and peripheral equ. a few months ago with a Burnham Series 2 (model 206xxx) My home has 3 zones and slab heat in the basement floor. The boiler bangs and thumps on start-up. Obvious conclusion was air in the system but exhaustive bleeding, installation of a loop (with shut off valve)and extra air scoop has not resolved the problem. The noise is coming from within the boiler itself, not the external piping. The installation contractor seems at a losss as to what to do next. Any thoughts?0 -
what temp....
is the boiler running at? How is the radiant piped? What was in there for a boiler before the replacement? Any zone valves? Any picts? kpc0 -
How many bangs and thumps ?
I think this unit comes with an isolation relay that might be directly mounted to the inner boiler jacket . Makes a good thumping noise on startup on a few we've installed in the past .0 -
check direction of flow
possible reversed flow with pump banging against zone valve0 -
My money is on:
Pump not working. Water boiling.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
I would bet on backwards zone valve, Tim
- 87.5K THE MAIN WALL
- 123 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
