2 pipe steam problems
Paul_34
Member Posts: 31
having anybody see this happen before.
I'm working on a 2 pipe steam system with a feeder and transfer pump. Have problems with feeder pump running most of the time to kept up with water level. The transfer pump runs not much. The condensate mains run along a wall below the water line and higher then the receiver inlet and then there's 2 45* fitting to pass around a jog in the wall and the second fitting is higher then the first fitting by 2". Then it goes another 20 feet to the transfer pump receiver inlet. right before it goes in to the receiver it drops down 2" before the inlet. would this cause a double water seal.0 -
2 pipe steam returns
can i use copper returns (sweated)instead of threaded black pipe0 -
they say it's ok to copper wet returns.0 -
can some body answer this question.0 -
I think
you might have another problem- does the feed pump shut off then turn back on quickly?
some times it will stay off for couple of mintues some times it says off for 20 seconds. the transfer pump doesn't run much.0 -
You might have
a bad check valve between the pump and the boiler.
"Steamhead"
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
