High efficiency steam boilers?
Tom Hopkins
Member Posts: 554
thank you
With everyones minds on optimum efficiency, what choices are available for our steam customers who want to replace their old steam boiler with a new high efficiency boiler? Like the 94% eff boiler their neighbor with a hydronic system got? Or is 83% all they get?
Thanks for your input,
-Robby0 -
Two Words
Burnham Megasteam0 -
OK, how about for natural gas?
Thanks0 -
Smith G-8
6% better thermal efficiency than the usual atmospheric boiler, give or take. And you can switch fuels without buying a new boiler- just change the burner and a few minor trim items. The gas burner used is the Carlin EZ-Gas; for oil you can get the usual Beckett, Carlin or Riello burners.
cool, thanks
One more question; What's the max efficiency for a steam boiler of about 1.5 mil BTU. I'm considering bidding with a Weil LGB but the property owner wants the most eff possible
-Robby0 -
that LGB would be about the least efficient
considering the standby stack losses, back losses off the burners, Losses off the jacket, etc. With a boiler that size, you should be looking at a wetback 3 pass steel boiler with a modulating power burner, or a couple of smaller steel or Cast iron boilers that are 3 pass designs, if possible, that are stage fired or modulated. I have tested older Burnham cast iron vertical section boilers that achieve 84 % efficiencies on an analyzer at low to mid fire. A 3 pass boiler would probably do even better on low fire since the heat exchanger would be better utilized I would think.
Boilerpro
Hey thanks, I don't know much about 3 pass boilers but I guess I'd better do some research
Thanks,
-Robby0 -
Start here
the Burnham Mega-Steam page:
http://www.burnham.com/mega.htm
This is the only residential 3-pass steamer being made so far. For residential hot-water check out the Biasi, Buderus G115, Burnham MPO, Slant/Fin Eutectic, Solaia and others.
Beautiful drop header.0 -
Thanks!
from Gordo and me.
- 114 Geothermal
