honey well AQ475A or Tekmar 260
Robert O'Brien
Robert O'Brien Member Posts: 3,584
is the fan controlled on the air handlers?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=313&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Steve_176
    Steve_176 Member Posts: 1
    Honeywell AQ475A or Tekmar 260
    I wanted to see if anyone would know which of the two would be best situited for this house. The house is currently using an oil boiler by Peerless, which is set-up on a hydro air system. The system has (2) 4 ton units running with 4 zones. Current use of oil on this home is about 2000 gals. a year, with sqaure footage of 6000. Currently it is using the Beckett Heat Manager, but it does not seam to show any improvement over the last year. Now we are looking at the Honeywell AQ475A or the Tekmar 260 boiler control. Which one do you think would preform better, and what kind of percentage savings would there be. Or if you have any other suggestions. Thanks
  • GLENN_14
    GLENN_14 Member Posts: 58
    heatm manager already a fuel saving device
    Steve,
    if you have a beckett heat manager already on the system you will not see a substantial difference in energy usage. Is the heat manager set up properly?? the function of the heat manager is to extend off cycle time during normal heating cycles and therfore adjusts the runtime of the boiler. I don't believe that addinig anything different will make a substantial difference.
