Horizontal Draft Diverters
Peter Zelchenko
Member Posts: 21
I was on a service call today and saw a Hydrotherm VGA-350-INT steamer w/ bad t/stat. After replacing t/stat I fired up system and noticed some bubbling paint on rear sheet metal panel and the rear and top of the boiler was very hot to the touch only after a few minutes of operation. Upon removing the back panel I was stunned to see that the rear burner base was basically melted (where the rear of the sections sit on the base)! I shut unit off and removed all burners and found 4 with broken slots towards the rear. The boiler is nat gas, all near boiler looks good (3" header, 2" drip, good "A" dimension), and looks to be only a few yrs old. The only thing that I noticed is that there is a 10" Horizontal Draft Diverter as opposed to a vertical. The ceiling height in basement is pretty low. Could this be causing the excess heat build up? Any thoughts are greatly appreciated. (Checked chimney and looks good)
Thanks, TJ
Thanks, TJ
- 114 Geothermal
