Any Experience With Taco RMB-1
Al Corelli
Member Posts: 454
Four in my Mom's House.
If I put them in my Mom's House, you know they are good.
Taco RMB-1 Experience
My contractor has come up with the Taco RMB-1 as the needed solution to the problems with the installation of my new Dunkirk boiler. See previous thread "Replaced Old Boiler With Dunkirk Wide Temp Swings Overshoots". It is an in-floor radiant system. It looks like it will do everything needed but I wanted to see what the opinions on the board are. Do I lose anything I need by operating it in the outdoor reset mode?
Thanks to everyone who contributed to the old thread.
John0 -
Installed lot of them
They work great. Just make sure your heating contractor follows the piping diagrams. I believe they are rated for around 80,000 to 100,000 BTU. I assume you do not need any more than that to properly heat your space?
Rocky0 -
I'm only heating 1400 square feet with one zone so should be good. John0 -
just have
a lot of patience getting all the wiring "dressed" (stuffed) into the back of the control. Major pinch point. The earlier models were a pain to actually mount on the wall- had to dissect the entire RMB. But, you got to know the thing intimately
RMB-1 rating
The RMB-1 is actually rated for 120,000 BTU. Taco is tops. Quality products from a quality company.0
- 114 Geothermal
