Gas water heater and storage tank combined schematic
Larry Weingarten
Member Posts: 3,725
... a schematic, but having connections between tanks, both high and low will allow convection to keep both tanks at similar temps. I'm imagining cold being fed into the "electric" tank and hot taken from the gas heater. When water is used, I imagine cold water filling both tanks evenly, giving roughly 70% of the volume of both, or 105 gallons.
It's an educated guess ;~)
Yours, Larry
Yours, Larry
Does anybody have a schematic for a 75 gallon natural gas water heater with a 75 gallon electric water heater for storage combined. The electrical part of the water heater i will not be using i only want to use the electric water heater as a storage with a bronze pump because a electric water heater is cheaper than a storage tank.0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
