Watts Backflow 9D
Bob Gagnon plumbing and heating
Member Posts: 1,373
Remove the 9D before turning the water on, and flush a whole bucket of water out to clean out the new piping. I used to have a lot of real slow leaks before I did this, no leaks after I started doing this. Thanks, Bob Gagnon
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=331&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Watts Backflow 9D
I have a watts vavle 9D on a shop radiant system dripping out of the vent. I replaced it 2 months ago and it started dripping again, you guys have any ideas?0 -
PUT A SWING CHECK BETWEEN BOILER INLET & 9D0 -
Also...
I've had luck with a check valve BEFORE the backflow device. We use a check before ANY backflow device, and have not had a leaker since.
This goes for the 9D, 909, etc.
Just curious what kind of tubing is in the system?0 -
is it a constant drip
or a once in a while spit?0 -
What is the presure
feeding the system ?
Scott
Do you use a large draw on the water system in the shop for washing or turn off the water supply to shop at all?
Both of these would have an effect on the 9D seats.0 -
check valve
n.y. state boiler code requires a swing check in addition to a backflow device & nyc boiler div. is enforcing this revision. after discussion with engineer i tend to agree it is a good thing. many backflows were failing due to temp. of boiler water. pres. red. valve apparently has integral check but .......0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
