lime chips for cond neut
Tim_59
Tim_59 Member Posts: 9
Can I just put some chips in a pipe and pump the condensate through it? Do I need contact time? What is the best/common practice?
Tim
  • Timco
    Timco Member Posts: 3,040
    Does anyone have a P/N or an online sourse for these? I have checked all my big box stores and need to fill my new cond neutralizer setup.
    Thanks, Tim
  • Dave_4
    Dave_4 Member Posts: 1,404
    marble chips
    are available at LOwes (prob home depot as well) in garden section in a 50 lb bag. I took some of them and broke up smaller to fill mine which works fine and pH came up nicely. Just have to find use for the other 40 lbs.
  • Tim:
    Most people I know just go to the local garden store and ask for a bag of lime chips. They are very inexpensive.
    Ordering on the net would incur shipping charges which would bring the price up higher than you could buy locally.
  • Timco
    I found the marble chips at Lowes, but it said nowhere on it 'lime'. Am I missing some basic geology??? My local guys said that the white marble chips were not the lime chips I am seeking...I made a pretty good neut container out of ABS & tapped my barbs in & out of it.
    Tim
  • jp_2
    jp_2 Member Posts: 1,935
    marble = limestone
    well, a google search shows marble to be a form of limestone.
    learned my lesson for today.
  • Timco
    Thank you for sharing your lesson. I am good to go!
    Tim
  • Terry O
    Terry O Member Posts: 67
    Another source of product is a local fish store.... fish hobbyists (been one for 30 yrs!) use crushed coral, oyster shells and a dolomite gravel for ph control in marine and african tanks. Most any fish/pet store will carry similar products.
    Terry O
  • albandjann1725849
    albandjann1725849 Member Posts: 19
    small sizes
    Be careful of small particle/grain sizes and highly porous limestone material. They may tend to turn to mush/paste and pose a problem for the condensate pump.
  • Mark Biro
    Mark Biro Member Posts: 46
    Forms of calcium carbonate -- many
    Yup, jp has it.
    Calcium carbonate (CaCO3) has the advantages of being common in the earth, benign, economical, useful for many things, available retail in many forms, and a neutralizer.
    You can, for instance, lime you fields or garden, to reduce acidity.
    A common sedimentary form of CaCO3 is limestone.
    A common metamorphic form of CaCO3 is marble.
    A common igneous form of CaCO3 is... dunno. Impossible?
    (Since it's marine shell-life that builds up usable quantities of CaCO3, if I have it right... ancient, or modern, as oyster shells.)
    So: farm stores have bags of crushed limestone, for liming fields, and oyster shells, for laying hens. Garden stores also have the crushed limestone, and sometimes even a finely-ground form, for sports field line markings -- too fine for neutralizers. Many sources, many forms... and cheap. The biggest challenge, it seems to me, is to resolve to throw most of a bag into your garden, rather than storing it as clutter, until needed far in the future. :-)
    Crush fine, and mix with linseed oil to form "whiting," traditional (now outdated) putty. ;-)
  • Tim_59
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    Hey Gregg,what is Sheetrock made of ?
  • Uni R_2
    Uni R_2 Member Posts: 589
    Gypsum
    So are most toothpastes.
  • Derheatmeister
    And that is also the name of the town near me where they produce sheetrock).... well ,Does Gypsum or sheetrock have neutralizing property's?
  • jp_2
    drywall
    calcium sulfate.
    probably work but would turn into soup.
  • Mark Biro
    Sheetrock = or <> Gyps?
    Oh, dear... and I am getting ready to sheetrock today, but not for a neutralizer.
    Back to you: What does "Gyps" mean in German? :-)
    And does that mean a blame thing for gypsum sheetrock? ;-)
  • Derheatmeister
    Gyps
    Ja das is so ,Or: Gipsplatten which is Sheetrock :das ist doch das gleiche ,or yes that's the same.
  • Dave Stroman
    Dave Stroman Member Posts: 765
    When I build mine, I like to run the condensate through the neutralizer before I pump it. Probably saves the pump from unnecessary corrosion. I also like to dump the drain tube from the boiler into a sort of stand pipe. This will prevent any fluid from backing up into the boiler if the neutralizer plugs up with "paste".
    Dave Stroman, Denver
