adding to steam heat
ed m
ed m Member Posts: 65
steam sounds like a good option,or you could run a hot water loop off the boiler if the steam option is not doable. i have also done radiant off steam boiler with heat exchange also another option,if the boiler has a coil you could use that instead of the heat exchange.many diffent ways to go make sure boiler is big enough,and which ever way you decide to go plan out the correct piping.good luck
eddie
