Insulation over slab
Don Regan
Member Posts: 43
2.5"? we use the 1" Crete-Heat with a 1.5 " light weight over pour. This gives you the thermo break you need or you end up heating the slab below.
I am about to finish my basement with an existing concrete slab. I will be installing electric radiant heating over top of this and am hoping to get some input on what products to use for insulation/thermal break. Styrofoam will be too thick
Any help would be appreciated 0 -
your kind...
of stuck then. Bubble wrap sucks. Wood will absorb miosture and rot. 1/2"poy iso board is really your only option...kpc0 -
or use the 2nd best heat emiiter...
Cast Iron Baseboard Radaitors.. Pricey, but can't beats the comfort when installed properly..0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 5.7K Gas Heating
- 111 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 49 Job Opportunities
