Tekmar 510 Stuck!
Chas_4
Member Posts: 29
I have tried everything. My Tekmar 510 will not switch from wake to sleep - occupied - unoccupied any more. Is there a way to reset it and reprogram it or do you think it has failed? It seems to be a software issue as everything else works.
Try powering off and let sit for 5 minutes
Then power back up and see if it resets. Tim0 -
I will try that
I will try powering it down. I have additional information at this point though. I have it set to 4 events per day, 7 days.
6:00AM - 9:00AM WAKE
9:00AM - 8:00PM UNOOCCUPIED
8:00PM - 11:50PM OCCUPIED
11:50PM - 6:00AM SLEEP
At 3:30 AM It said it was occupied. I tried everything. Setting it to 11:40PM made it go to sleep! Yet if I set it to 11:50PM its occupied. I tried the ---- setting which is supposed to be midnight but it didn't work.0 -
ask the inventor
Why not contact tekmar engineering support ? who knows more about it than them ?0 -
I will call them.
I was going to call them on Monday. Must be a way to reset them to the factory settings.0 -
If you push the up & down buttons at the same time, and hold them for 3-5 seconds, it is supposed to go back to the pre-set program from over-ride. It has a limited power-off memory, and may need to be powered down for 30 min...I do not remember how long the memory is good for but it can withstand a short power outage and keep it's memory.
TimJust a guy running some pipes.0 -
Memory
Yes, it holds its memory including accurate time for about 3 1/2 hours. Any longer and the time jumps ahead or behind a bit. It retains its programming forever. Well, 24 hours at least. It is a great little stat but has some programming odities and now somewhat flakey behaviour. Only on Fridays too, all of the other days are working.0
