One pipe Steam heat oil or gas replacement?
a boiler that can use either fuel? Take a look at the Smith 8 series, which is available from the factory with oil or gas burners, and can be easily changed over in the field. This would let you burn whatever is cheapest per BTU.
Here are a couple we've installed using gas burners. The boiler is known as the G-8 when using gas.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Eray
    Eray Member Posts: 1
    Replacement Boiler
    What is the best technology to replace an old oil fired steam boiler with? This is a one pipe drain back system. Oil and Natural Gas are both available.
    Which fuel be more cost effective?
    What is the best boiler?
