splitting existing hot water heating system into two zones
dennis setzer
Member Posts: 3
have added pellet stove to living room and due to location of thermostat back end of house gets cold due to fact that
boiler doesn't run. don't use pellet stove all the time
I have hot water heating system consisting of Edwards 125K
BTU boiler. House is approx 1400 sq ft. Boiler has a manifold. Want to split house into two zones. Bedrooms on one zone rest of the house on another . Any suggestions? thanx0 -
radiators
Or baseboard?0 -
reuse the pump
add two zone valves - mix in an assortment of nipples and fittings - don't forget isolation/balance and purge/drain valves
sounds like a good project for the summer!0 -
all radiators are baseboard0 -
Objectives
Dennis,
Your boiler already seems tremendously oversized for your home. Splitting the zones will lead to shorter run times if not short cycling which will decrease efficiency and increase maintenance costs.
What is it that is making you want to consider zoning?0 -
One idea...
One idea might be to move the t-stat away from the pellet stove's influence and then use one or more TRVs to control temps in that area depending on how your baseboards are piped.0 -
baseboard units are one series loop. really need to trv one unit in living room. would this require bypass for baseboard unit?0
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 5.7K Gas Heating
- 110 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 999 Plumbing
- 6.3K Radiant Heating
- 391 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 45 Industry Classes
- 48 Job Opportunities
