NTI
150,000 btu trinity, built into a cabinet w/ coil for forced air HRV, and flat plate for DHW. Just helped install one of the first in WI. HRV still needs to be balanced, but It's a pretty impressive unit
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    NTI
  • Derheatmeister
    Ups,Sorry for the Pre post, anyway I've seen this Hydroair system from NTI(Trinity):It is as stated a hydro air system that uses a Modcon boiler to a air/ heat recovery system and can also produce hot water! I,ve made my own Baxi/airhandler/hotwater setup and it fits in a furnace replacement(thigh Closet)but will rather just Plug and play The heat exchanger looks just like the Baxi's . does anyone know more about these boilers or this setup or other manufactures that are doing this? thanks for any input.
  • Derheatmeister
    Do you know the Baxi and does the exchanger look the same? if you know the Baxi ,it has a Siemens QAA73Thermostat/Controller which is very nice.Does the NTI also have a stat/Controller?
