Thermostat choices with Taco SR502
Baldrick_2
Member Posts: 6
This is a last piece in my puzzle.
2 zones:
- high temp underfloor
- low temp slab
1 primary pump, 2 secondary pumps (one with I-series setpoint mixing valve), Trinity Ti100 w/ Sentry 2100 control, Taco SR502 switching relay).
There already is one thermostat in a slab zone (it does central air heating and cooling). I am not sure if there is a thermostat that would do all in one (3 sources: central air HAC + radiant H) or I should just add on another dedicated heating only thermostat?
Second zone thermostat would do radiant only.
Any suggestions? Tekmar? Honeywell?
2 zones:
- low temp slab
- 114 Geothermal
