gravity heat problem
aidan_2
Member Posts: 4
i recently ripped out an old radiator and replaced it with a 3 foot piece of slant/fin baseboard,i piped it like a radiator with a coin vent on top,i then refilled the system venting everything now everything but the baseboard is working,did i do something wrong?.grateful for any help.
no way that...
will work. Fin tube is low mass high flow heat emitter...gravity systems are low flow high mass systems. You need the proper size pipe and rad. kpc0 -
Baseboard
What is the pipe size of this section of HWBB? 3/4"?
HWBB and CI Rads have different flow characteristics. The pressure drop of the smaller pipe in the HWBB creates resistance. The water will travel the path of least resistance therefor the water isn't jumping off the larger main to take the ride along the section of HWBB and continuing on down the road in the larger main to the next Rad.
Was space consideration your motivation in replacing the Rad w/HWBB?
We just finished a similar project that the previous owner removed numerous Rads and replaced them with HWBB...Needless to say we had to repipe new distribution and add zoning to separate the two different types of heat emitter.
My $.020 -
thanks kevin,would cast iron baseboard work?0 -
makes sense jim thanks,0 -
- 114 Geothermal
