weil mclain oil steam
jay_39
Member Posts: 1
i have a weil mclain oil fired steam boiler. Its now 5 years old and every heating season it fails me since i had it installed. it currently fires, stays lit for approx 5 sec. and shuts down. anything will help
serviced?
Jay,
When you say it shuts down are you saying the burner locks out and you press the oil burner reset button to get it restarted? Or is it short cycling on and off?
Is it safe to assume that you haven't been dealing with this same symptom for 5 years?
Steam boilers require flushing of the low water cutoff every week in the winter. Are you doing this?
Keith0 -
It sounds like theres too much combustion air supplied to the burner and the shuttering fire is tricking the cad cell eye into recycle mode.
However, if your having to press the reset button each time to get it started it can be something completely different.
Either way the solution is to call a professional for service.There was an error rendering this rich post.
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
