Levittown Manifold
Dan,
Very valuable and a great tool. The pics are good but I am looking for someone whoactually has worked on one :-)
and THANKS for sending me a copy of that stuff!!!
Steve
  • The Rancher Manifold
    Does anyone know which loops off the manifold service the master bedroom?????
    thanks,
    wheels
  • Kevin O. Pulver
    Kevin O. Pulver Member Posts: 380
    Steve isn't there
    a place here somewhere that had pictures of the layout AND a layout diagram/illustration? I don't venture off the wall enough to know where I saw it, but I think it's here.
    Kevin
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,616
    This is the best I can do.
    It's from the Library: Levittown
    Retired and loving it.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,122
    The Front Bedroom too Cold?
    That's normal......
    What
    happen fifty years ago ... They were banging out those homes so fast the plumber barely had enough time to roll out the copper because there was a cement truck and floaters up his ****. Forget about fastening it down. Most of the loop was pushed back toward the rear. So the front bedroom is cold with the radiant heat and ends up too hot when they convert to baseboard. That 10 x10 room ends up with 22' of bb. Of cause you should use 12' of dummy
  • DanHolohan
    Oh.
    Did you try looking under the Old Fogey tab (on the masthead)? I think we have a guy in there who can help. :-)
  • Wow Dan...
    You sure do got a lotta good stuff! ;)
  • so now you want a heatloss???
    Big Ed,
    Do youi mean you are not supposed to run the BBD cover AND element WALL to Wall?????
  • DanHolohan
    The Library
    is turning into quite a place.
  • What type of boiler ?
    Is it on the floor or hanging on the wall ? We have a plumber who still repairs original Levitt radiant . I'll ask if he knows which pipes go to the master bedroom .
    Big Ed , the back bedroom is usually the master . But you're right , the front bedroom is always the coldest with radiant .
  • FLOOR
    Ron,
    Floor mounted boiler. This is on the ranch that they left the attic and unfinished 2nd floor.. wink wink.
    steve
  • Derheatmeister
    Derheatmeister Member Posts: 1,607
    This is great stuff brings back some memory's of working on some old infloor systems in Closter NJ but it was Iron Pipe/no edge insulation so the tulip's would grow around the house in January
