Refurbish Radiators
Rosalie
Member Posts: 1
I recently moved into a 1920's home in Bergen County, New Jersey and have 14 radiators that I would like to have stripped/sandblasted and repainted. Could someone refer me to a company in my area who provides these services?
I believe the radiators are all plain corto style.
20" tall - 5 tubes - 21 sections
20" tall - 5 tubes - 12 sections
20" tall - 5 tubes - 07 sections
36" tall - 5 tubes - 21 sections
20" tall - 3 tubes - 04 sections
20" tall - 5 tubes - 09 sections
36" tall - 3 tubes - 04 sections
20" tall - 5 tubes - 15 sections
20" tall - 5 tubes - 16 sections
20" tall - 4 tubes - 07 sections
Thanks.
Thanks.
Regarding refurbishing
I am sure someone in your area will respond. One of the tough things on these jobs is getting someone willing to transport. When we do it, if we realllllly have to, it is a lot of work getting the radiators out of house and to refinisher. Expect a fairly large bill to refinish and to transport. The company who decides to do this for you may want a transport company to take and return radiators. They may just come and shut down and disconnect and then you would have a mover come in and take & return from finisher. Good luck, Tim0 -
Powdercoat
May I suggest powdercoating rather than painting? It's more durable, come in a myriad of colors, no off gassing (that I could tell) and looks great. Was comparable in price to having them painted. We're slowly refinishing all of our steam radiators this way and LOVE the results.
Good luck,
Patrick0 -
Radiator Refinishing
I spent $12 per fin for sandblasting and painting in a shop. Then it was $100 round trip for transportation, per radiator. I chose to do only three of my 17 because of the cost. Two I painted myself with a can of spray paint when I had them disconnected and in the middle of the room under renovation.
I'm in Missouri, so I can't make suggestions on contractors/painters.0 -
That is a great deal
Here they charge about 40 per section to blast and paint give or take 10 depending on size and quantity.0 -
Hot tank?
Is hot tanking (hot caustic), as is done to clean CI engine parts, etc. a viable alternative to sandblasting? Perhaps at a auto/truck rebuild/machine shop. Ought to leave the CI clean enough to eat off of. You probably want to plug/cap the inlet/outlet and vent/bleed openings though, as it might be a bear to drain/rinse otherwise.0 -
Arthur Greene in Union NJ 908-687-4419. Contact your local paint store, or look up sandblasting in a phone directory.0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
