Leak on Munchkin?
bobbyg_2
Member Posts: 139
Here is some information from the factory. This applies to newer units.
Please read carefully to make sure this applies to your unit.
Leak on Munchkin?
Hey,I'm looking for some Pointers on that to take on this Service call: the equipment is a 140 Munchkin and it leak's at the condensate Drain in the back of the boiler, I've heard that i Should tilt the boiler towards the back so that the Condensate drains Freely.I also hear that back drain setup (where the condensate drains out of) can deteriorate. It is Leaking from the back now,the pan it sits in is completely rusted away and i need to remove the boiler to replace it. It is the heating season and i hate to have to wait for parts on this just because i pulled something apart. Thanks for any input.Richard von Heatmeister.0 -
Thank you for all of your Advise.Richard0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
