Goodman Gas Pack
Bryan_16
Bryan_16 Member Posts: 262
when you see as many of this brand with these symptoms, 100% of the time is cracked HX.
  • Goodman Gas Pack
    I have a Goodman Gas Pack about 5 years old, it keeps tripping the roll out switch, doesnot seem to have a cracked heatexchanger, seems to have good airflow. We even changed roll out switch just to be sure. It happens periodically, any ides
  • Bryan_16
    Bad heat exchanger
  • snake
    snake Member Posts: 1
    Get a ridgid see snake and take a look and you will see a cracked heat exchanger.
  • jim lockard_4
    jim lockard_4 Member Posts: 13
    The Snake
    Maybe you will and maybe you will not see the cracks with the snake. But rest assured you have a cracked/damaged heat exchanger.
  • Hvacman
    Hvacman Member Posts: 159
    WOW
    I'm no fan of certain brands but shy away from condemning heat exchangers from my seat in front of the computer monitor... Perhaps the OP should seek a second opinion from a local professional? Failing ID fan or rotting collector seem equally as plausable from where I sit. :-)
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    Dead Critter?/Snow Block.?
    OR, Can it be That a Critter(Bird/Tree Rat)Was monkeying Around the Exhaust Fainted because the Furnace turned on, and then Died in the Exhaust.check for it,Seen it Before.
  • tim smith
    tim smith Member Posts: 2,886
    soot in heat x, dirty inducer wheel, etc etc
    Could be any of these let alone a cracked heat x. Need to look better. Pull top of unit is easiest to see heat x fully.
