Honeywell/Sparco/Uponor zone valves
ed m
Member Posts: 65
in the honeywell 5000 series m# v8043f zone valve which has terminals built in to the bottom of valve, do they make a bx adpater or connection for that so you do not have exposed wires?
thanks for the help
eddie
thanks for the help
eddie
Feedback please
Has any one used these zone valves from Uponor, with the thermal heads mounted to the Honeywell/Sparco zone valves?
I just received a few , thought I'd give them a try on a few single zone manifold configuration.
I have several contractors using the actuator. keep in mind it is slow acting and may take several minutes to actuate.0
