Glycol for hydronic systems. How to calculate amount of glycol t
Drew_2
Member Posts: 158
George
Dan gave you the link to our website. Look under technical then fluids. If that doesn't give you what you need, give me a call. I'm on EST the number is 800-678-6625, Ext. 108
Drew
Drew
Glycol: How to calculate amount necessary
How do I calculate the amount of glycol for a hydronic heating system? Is there any texts that have this info? I have looked a Modern Hydronic Heating and Modern Heating, Ventilation and Air Conditioning but can't find info I need. Any help would be appreciated.
It depends on volume
George,
It depends on system volume. Calculate the volume of all the pipe, indirect coils, fan coils, and boiler. Then you take a percentage of that to give how much glycol to put in. Most people use a 30% mix, but if you are doing a snow melt you may wish to go to 50%. Your supplier of glycol should have a chart that will give you the right percentage for freeze/burst protection that you will require. Hope that helps.0 -
Noble Company
has some good information on this. They sponsor the Library on this site. Here's a direct LINK to a page that will be helpful. Scroll down a bit when you get there.Retired and loving it.0
