oil gas and wood stove in same chimney?
david_49
Member Posts: 1
i have an oil fired furnace and a natural gas water heater. im thinking about getting a wood stove. does anyone have any in-site or knowledge of wether or not i can put the wood stove into the same chimney?
oil and....
gas ok...You need a separate chimney for the wood stove.
Just ran across one Charmmaster (Wood/Oil burner furnace) I had problem with that at first too since it's not up to german code but after talking to the company that is still in business they assurde me that they can use a common vent and the boiler is designed that you cannot use both a the same time. will be Changing the Oilburner tomorrow.0 -
Sorry i did not read you post correctly .No you cannot use a common vent!0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
