Turning heat up and down daily on a boiler
Bob Forand
Member Posts: 305
I would not adjust the temperature. It costs more to heat the space a second time than if you had just left it. Especially if it takes two hour to bring it back up.
Adjusting temp on a boiler each night
Is it wise to turn down temp on a boiler in a commercial building by 10 degress at night? - it seems eveyone complains on how long it takes for the building to heat back up in the AM (up to 2 hours)and people randomly walk in and adjust the temp up to try to get a "quick" heat shot to particular areas of the building. Note: this is an old building but the boiler has been maintained and was replaced about 6 years ago0 -
adj temp
if its an older building with little or no insulation then the answer is no better to not turn down thermostat more then a few degrees0
