Should 180 degrees be enough
Chris S
Member Posts: 176
We design for 180 degrees with zero degree outdoor temp.
If it's below zero with wind chill as it will be tonight and there is no cushion built into the design, the only answer is higher temperature. I like to modulate the temp automatically with an outdoor sensor.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=543&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
On really cold nights 10 degrees plus wind chill I turn up my hi limit to 200 because the house just doesn't keep up.
I have new windows. Do you guys always leave hi limit at 180 and your home is able to get to 70??0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
