Help with Munchkin
[Deleted User]
Contact my good friend/supplier at Water Systems, Inc, Charles Potter (no relation to Harry)
303-629-6122
Everytime I call over to check on an odd ball part he cheerfully responds "Uh, yeah, I've got, like, 12 of them...;-)"
Good Luck buddy. If you need the reps numbers, you have my cell number.
BTW, suspect slime, causing a back up. You need some "Earthtrons Booger Buster" for your drain lines :-)
Can I send you a railway car full today?
ME
303-629-6122
ME
Help with Munchkin
hey,I've got a customer that has a munchkin that needs service. I normally do not work on them(I Install and service Viessmann/TT Prestige/Baxi's) but i want to in this case. For one it's leaking from the back of the boiler and as far as i remember there was a posting about something with the Condensate Trap that deteriorated. The system is running on a fixed high temp. it's running now but needs servicing i am just not a Munchkin parts stocking guy and am looking for advise on what to look for and which parts i.e.Gaskets/Switches/sensors i should order and have on hand when i service this boiler. Thank's Richard from Heatmeister0 -
Thanks Buddy ,I've call him and i got some parts coming!0 -
Does it work?
For sinus problems Mark?0
