mod/con boiler?
Mitch_4
Member Posts: 955
Depending on your system there are a couple options.
In a smaller load (say 40-50Mbtu) single baseboard loop, I recommend a fixed rate condensing boiler and outdoor reset.
The cost savings modulating from 25-50 would be a long payback for the extra technology required in modulation.
Using a small condensing boiler, and an outdoor reset to modulate your water temperature is simpler in design, cheaper on installation costs, and you ge the benefits of condensing technology 90% of the time. (I typically lower the high limit on fixed input units to 160 and still have no trouble.)
Now if you have a larger system with many zones, or are looking to zone you home to 3+, then a small mod con will make sense because the load varies as more zones go on and off line.
Find a pro, ask questions, and if unsure of the reply post it here, you will get the help. don't ask about prices though..local conditions will affect that
Im planning on replacing my heating system. Ive read a lot on this site about mod/con boilers like the Vitodens 200 and they seem to be the most energy efficient.
In floor radiant is not an option for my house.
Are mod/cons an appropriate boiler to use with either baseboard radiators or radiant panels? Im concerned because of the low operating temperatures of the mod/cons and how the low temperature would work.
I realize the baseboard radiators or radiant panels would have to be sized appropriately for the lower operating temperature.
Would a regular high efficiency boiler be more a cost effectiveness than a mod/con?0 -
What boilers are out there that
condense but don't modulate?0 -
MOD/CON
Educate yourself and find a good heating tech. How much efficiency can you afford? As stated earlier, consider the amount of time to pay for the efficiency increase.
http://www.hpac.com/Issue/Article/24498/244980 -
Non modulating Condensing boilers
Personally I use the Olsen in Canada. In the USA they are the Utica UB90 series, and the Dunkirk Q90. made from 50,000 - 200,000 input in 25k increments
Google any of the company names for their websites.
I have had great success with the 50 and 75 for retrofits up to about 3000 sq ft homes usually.
Mitch0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
