21\" 3-column EDR
steve_173
Member Posts: 140
I have some 21" 3-column radiators that I need an EDR for. The tables seem to only have 18" and 22" for 3 column. Does this indicate that only 22" were made and I am measuring incorrectly? Are there more expansive tables?
How do I calculate the EDR just from the dimensions of the radiator?
steve
Allow 3 sq. ft. per column, and you should be OK.
The slight difference is negligible.0 -
Thanks. Just to be doubly sure since I may have to argue about it. 2.25 is too low?0
- 86.7K THE MAIN WALL
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
