Wonder when aftermarket mod con repair parts
Ross_7
Member Posts: 577
I thought that you had said before that you installed Trinity. I know that you have posted some pics from some of your jobs before. I guess the rumor around the campfire is that TT is coming out with a smaller btu Prestige (15-60mbtuh) model in a few months. Should fit the bill for smaller applications :-)
Ross
Ross
will start hitting the shelves
Sure would be nice to pick up a flame rod, module, or EBM motor at a Johnstone Supply, for example.
I'd rather they stocked, and paid for a selection of brands, then me
hot rodBob "hot rod" Rohr
Living the hydronic dream0 -
Yes !!
Dito ,I've got to stock Parts from Viessmann/Baxi's/And Triangle Tube . As per the Triangle Tube There Kit is Just Wonderful!!! It make's it Easy,and look's Professional When you Walk into a No heat call ,Open you Case and Repair it,Then,Now,Doen. Is that Not Worth the Grand that they Get for this Kit?. As For Buderus i find that there Parts are Overpriced,I've got a Blower and a Pressure Switch. If you Think about it, It Would be in The Manufactures Interest to Offer these Kit's.Maybe even for a Reduced Price(Startup ) So that when the Boiler Does Fail (Allways on Fri Night) you can Help your/There Customer.0 -
That is one reason I have stuck with one brand. I carry all the repair parts for the boilers I install. I am thinking about switching to the TT. I guess I will be buying their repair kit too.There was an error rendering this rich post.
What's you main boiler line, Dave?
What are you installing for boilers right now, Dave?
J/C
Ross0 -
I started using Trinity boilers and just stuck with them. The early ones had a few problems, as did other brands, but all in all, I have had good luck. Some of them are getting old enough now where I should be letting the homeowners know that service and cleaning should be done on them. That is one reason I am looking into the Prestige. They claim the HX do not need to be cleaned out. It makes sense the way they are designed.There was an error rendering this rich post.
Gee. At this altitude I seldom have a need for that small of one. I think the gap that needs filling is between 200 and 400. I know that TT has a 250 and Knight has a 285. I would like to see one about 300. I am bidding a snow melt job right now where at 125 Btu's per sq. ft., a 300 would fit just right. The 250 is probably what I will go with. It is too much of a jump to go to the 400.There was an error rendering this rich post.
