Need Replacement Air Handler for Hydronic System
Michael Anderson
Member Posts: 3
Greetings! We are an apartment building with a 40 year old Triad Sales Corp. (Chicago) loop boiler system for heating and an 80-ton chiller for cooling.
Last week one of our elderly tenants turn the lobby into a drive-thru wiping out the built in air handler in the lobby.
We need to replace this air handler with something comparable that has in-take in the front with venting discharge out the top to ductwork. This will also be a useful reference for replacements in all of the apartments.
Dimension are roughly 24W" X 34H" X 18D".
Thank you for any help!
Need more info
Know anything about the BTU capacity of this air handler? CFM capacity? Model # and brand of old one? 2 pipe? 3 pipe? 4 pipe?0 -
Thanks for responding.
Do not know the BTU Capacity
We believe the CFM is 600
Brand Triad Sales Corp outof Chicago, IL
Model # is TVSF-600 on Triad label located on blower
It is 2-pipe, one in and one out.
Thanks again0 -
Could you post photos
of the point of impact?
Not that it will help us solve the heating issue, just that some of us like to watch accident sites and that one sounds awesome -provided no one was hurt of course...
Kidding aside, is there any connected ductwork? Grilles? Feeding pipe sizes? Those might help determine a capacity.
There are a number of manufacturers of vertical fan coil units that could fit that space. What kind of space is available (meaning what tolerance in dimensions might there be to accommodate a similar unit with varying dimensions)?0
