FASTENING TUBING
hot_rod
hot_rod Member Posts: 24,507
the least expensive is a roll of plastic plumbers tape, that thin perforated strap. Cost you two nails and a bunch of cutting but it is a thin, and cheap as you can go.
Single or two hole electrical straps work as do copper coated plumbing straps. If it is a concrete or gyp pour that works, I'd worry about tube movement in metal straps if it is not in a concrete pour.
Sioux Chief and others make Tube Talons with a nail already in the clip. About 1/4" thick over the tube, however.
Here is a selection in various tube sizes.
hot rod
  • jhansen
    jhansen Member Posts: 59
    FASTENERS
    CAN ANYBODY RECOMMEND A GOOD LOW PROFILE U SHAPED FASTENER FOR 1/2 INCH PEX TUBING WHICH WILL BE COVERED IN A SHALLOW WET SYSTEM?
