Proper technique for attaching steam radiator to valve
ed wallace
ed wallace Member Posts: 1,612
if its a wood floor carpet scraps nap down allows you to slid rad around and to better line up the rad
  • Pete_18
    Pete_18 Member Posts: 197
    Any tricks?
    Are there any tricks to getting a good seal between the steam radiator and the supply valve?
    I am able to attach it without any issue, but with about 1/2# pressure (coldest day of the year), some steam begins to leak out between the union (whatever you call the valve piece on the radiator side that connects in with a spud wrench) and the valve.
    I assume that I am not getting the inner part of the union lined up perfectly with the valve, but I don't really know what the best way is to get them lined up properly for a good connection.
    Is my valve just horrible and I need a better brand or is there a trick to getting the two pieces to line up properly?
