Saved by pressure switch
hvacfreak
Member Posts: 439
I've posted about my new Amtrol digital pressure switch ( well system ) recently , but check this out...
I went to use some water yesterday afternoon , (after laundry , showers , dishwasher ) , the water barely dribbled from the faucet. So , I go down to the pressure switch and it is displaying " E3 " error. So , I check the paper and E3 is " improper voltage ". My first thought was that I had a loose connection or something , so I grabbed my meter and checked voltage , it read 275 volts . I used a second meter to confirm that I had 275 volts being supplied from the power company. Wall outlets read 138 volts.
I called the power company and reported my findings. I checked neighbors houses on each side of me , each was ok. The linesman traced the problem back to the transformer at the street. He called for the new transformer and a second truck , they changed it out in 15 minutes ( and were happy that they were working on double holiday time ).
I'm not sure if any damage was done to electrical devices in my house , or what might have happened if the over-voltage continued. I think that pressure switch may have saved me alot of grief.
now thats very intresting
Mike thats a great catch.Good thing you looked into it.had a custermer had his line from the pole wear thru and sent 220 volts back up the ground and fried just about everything in his house.
link
http://www.amtrol.com/amtrolr.htm
I'll never be without one of these for sure. I have sworn off those little grey boxes forever .0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
