Staple Up
Pinball
Pinball Member Posts: 249
Be very carfull where you drill! most T.J.I manufactures are very specific on where you can penetrate. Typically 18" from load bearing wall (inside of foundation) and whatever size hole you drill you have to be 6x the diamater to the next hole
however, you can make a hole as BIG as you want as long as you leave 1/4" on top and bottom. After having to pay for a replacement TJI, I always check with th G.C. or homeowner and have them ok every hole to be drilled, Pryor to spinning the steel!
Al
