still contemplating the pipe to use for the PAH home
Weezbo
Weezbo Member Posts: 6,231
this too could use a dash of viessmann solar:)
  • Weezbo
    thought ABS,..Then PVC...
    now i am considering using the liner for large underground utilities sewer pipes. the prices i am finding are near the cost of a decent boiler. could not find any salvaged pvc or abs ...
    the liner is expanded with steam :) i am after it today . if it turns into a viable solution i may be buying 10000' quantities of this liner pipe*~/:) my buddy Dave said it comes sorta squrinched ,i add steam,it expands Voila! Pipe:)
    Singh, how is the job comming that you were working with? what are you considering using for that aspect of the passive air for heating and cooling?
  • The only thing on the schedule for PAH's home........
    is solar! Final details are in-the-works.
  • singh
    singh Member Posts: 866
    weezbo
    I have the fine boys at N&S supply helping.
    We're looking into underground duct work for dehumidification.
    The pool room seperate system.
    I have a question for you, this is a going to be constructed on an Alaskan slab.
    I have to ask, are homes in Alaska really built with this system common? What are the traits of this, moisture, movement, etc..
  • Weezbo
    Singh...
    the correct way to roll is to use the insulation. the engineers give alot of grief over it however, i have seen some fine systems(insulated monolithic pours) done properly ,with far less rebar by the way.
    last year we did two properly. one was a shop. and one was a home with one wall of glass ,near the river With cathedral ceilings over the living room area. walking in you would think you were in a church the ceilings were That High :) both preformed well.
    the house had a slab i could drive a D-12 with the blade and 9'Ripper up ,onto it and park:) the other was the shop. the shop used fiber reinforced cement with 6X6X9 mesh and a couple runs of 5/8th's along the footing portion and a 6X6' 3/8" rebar squares laid over the mesh.... guys all habby*~/:) contractor went "with" it and the owner has a clean burn waste heated slab:) no wicking no movement,.. there it is and functioning right:)
    at this juncture, my buddy is considering a 60 X 200' shop avec offices. were i the engineer ...:) well, i would go with the foam everywhere the wire mesh heavy up the rebar on the fotter portion of the monolithic and lay in 3/8 on 6X6 over the mesh and lay in some rail road sections for the operator so he can run track equipment in and out the door:)
