raypac pool heater
D lux_2
Member Posts: 230
Installer NOT me didnt wire motor for inducer for 110 V factory wired for 220 V motor wouldnt turn fast enough to move switch
anybody work on raypack pool heaters?
haveing powervent not closing pres. switch D2 power vent thanks0 -
Raypak pool heater
Assume gas fired? Are you qualified to work on this? If not, you should call a pro. That said, check the sensor tube & ventor wheel for debris/blockage.0 -
mag gauge
Check your pressure switch with your mag gauge if in spec. change the switch if not change the powervent.0 -
Motor,..
Might want to replace it Now since it probably ran so hot and damaged the windings as a result. Also as a quick refference, Your amp probe would have giving you the answer if you used it,...
No dis... intended:-)
Mike T.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 110 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 981 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
